March 24, 2003, 10:03 |
Mesh Quality
Hi everybody!
I'm trying to analyse the quality of the mesh in the model that I'm working with. To do this I used the "Mesh Calculator" for check the Max. and Min. Face Angles, Element Volume Ratios, Edge Lenght Ratios and Connectivity Numbers. For the first and third variables mentioned I obtained good results, but for the others I obtained the following... Element Volume Ratio, Max=51.78 and Min=1 Connectivity Number, Max=78 and Min=2 The table from page 140 in the CFX Post Help for tetrahedrons elements indicates that elements with Volume Ratios over 5 and Connectivity Numbers below 50 can be a problem. My physical result are acceptable so I don't know if is really important to pay attention to this mesh variables... I'll appreciate if someone can give an advice to this respect. |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
[snappyHexMesh] mesh quality control and fix | tachyon_me | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2009 12:48 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
