shear stress scalar definitions?
Old   April 6, 2003, 01:45
Default shear stress scalar definitions?
Novak Elliott
Hi all,
In the CFX solver manual there is listed several user scalars quanitfying the shear stress:
XY NODAL SHEAR STRESS | YZ NODAL SHEAR STRESS | - defined at all cells ZX NODAL SHEAR STRESS |
and
X SHEAR STRESS | Y SHEAR STRESS | - defined only at boundary cells Z SHEAR STRESS |
However, I was unable to find definitions of these 6 values. Am I right in assuming that the XY, YZ, ZX NODAL SHEAR STRESS values correspond to the 6 pairs of shear stresses on the 6 cell faces, that is: TauXY = TauYX = viscosity * (du/dy + dv/dx), TauYZ = TauZY = viscosity * (dv/dz + dw/dy), and TauZX = TauXZ = viscosity * (du/dz + dw/dx) respectively?
Also, at a wall boundary there are two orthogonal shear stress vectors tangential to the wall. Are the X, Y and Z SHEAR STRESS scalars the x, y and z components of the vector sum of the two shear stress vectors? In which case, for a wall that is located, for example, in a z-plane, the X and Y SHEAR STRESS scalars are simply TauZX (=viscosity*du/dz, dw/dx=0) and TauZY (=viscosity*dv/dz, dw/dy=0) and Z SHEAR STRESS is zero?
I intend to calculate drag force and I'd rather make use of the inbuilt scalars than calculate the partial derivatives myself (although GRADV looks obvious enough).
cheers, Novak.
Shear Stress Calculation in the flow. auburnuser FLOW-3D 11 May 12, 2018 13:49
Fluid wall shear stress Sinead Kelly (Kelly) OpenFOAM Running, Solving & CFD 2 March 30, 2011 06:41
How to get shear stress all over the flow domain lingo FLUENT 2 November 3, 2003 21:16
WALL SHEAR STRESS Min-Hua Wang CFX 0 April 3, 2002 17:40
What is the detail definition of wall shear stress zjm FLUENT 0 January 2, 2002 07:43
