Mass fraction via Cel file at outlet
I have a problem when I would like to calculate the averaged mass fraction of a mixture at thought the outlet. The case is mixing two fluids in a large tank. The fluid is extracted using an outlet with a pump and then injected at another possition in the tank. How can I calculate the averaged mass fraction thought the outlet area and then use this to specify the mass fraction at the inlet ??? Thanks. Regards Jens |
Re: Mass fraction via Cel file at outlet
Hi Jens,
Assuming a multicomponent fluid called "Fluid", a component named "componentA", and you are measuring flow at a boundary named "Outlet", the following expression will do the trick: massFlowAve(Fluid.componentA.mf)@Outlet Regards, Robin |
In CFX 4, you can write a output file using Command file:
:>PATCH DATA PATCH NAME 'OUTLET' FILE NAME 'OUTLETAVERAGE.DAT' AVERAGE SPEICES1 EACH TIME STEP |
Hi
I am having some problem setting the mass fraction using the method you describe. I keep getting error: "and then error found at item: massFlowAve unrecognised name Error processing expression: Mass Fraction = scAn error has occurred in cfx5solve: " I define the massfraction in the cel file as: sc = massFlowAve(Mixture.SodiumChlorite.mf)@outlettop Can you give me any hints on what the problem is ??? Thanks Regards Jens |
