force coefficient computation
Old   May 6, 2003, 08:57
Default force coefficient computation
tascflowuser
I an simulating flow around hemisphere cylinder configuration. In supersonic range the force and moment coefficients match very well with experimental data. But in low speed subsonic range theses coefficients are not in good agreement with experimental data.What is the reason? I am using TASCflow and CFX5.5. I have tried meshes of different resolutions different discretization schemes and different turbulence models but I am unable to get accurate results. In some cases percetage difference between experimental and CFD results is about 200%.
Force and Force Coefficient ata OpenFOAM Post-Processing 9 August 18, 2021 13:44
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Viscous force and coefficient viscous force tobino Main CFD Forum 0 February 20, 2011 21:06
Automotive test case vinz OpenFOAM Running, Solving & CFD 98 October 27, 2008 08:43
Lift force coefficient for 2-phase flow Summer FLUENT 0 April 29, 2008 17:58
