Problem on importing IDEAS mesh
Old   May 13, 2003, 05:26
Default Problem on importing IDEAS mesh
Bernd Horlacher
Dear all,
I'm a CFX5.5 user and I'm trying to import an IDEAS hexahedral mesh (universal file). The problem ist, that the 2D-regions which were created in IDEAS by groups (nodes, surfaces,...I tried all) are not available in CFX5. Is there anybody who can help or give me some ideas? Thank you for your help.
Bernd
Old   May 20, 2003, 18:09
Default Re: Problem on importing IDEAS mesh
John K
I had a similar problem importing a mesh from StarCD, even written in Patran format which is what CFX5 requires. It is one of my continual problems with CFX, the inability to import anything into it. I ended up writing a translator to get from Star to CFX. If you have documentation for IDEAS Universal (or can you write a Patran format file?) format and use Patran documentation (the CFX info is a little sketchy) to find the required formats and fields for CFX all you need is a bit of code in between... I cannot provide you with any framework since my translator was developed whilst working for a large engineering company and is hence copyrighted...
Old   May 21, 2003, 03:09
Bernd Horlacher
Hi John,
many thanks for your response. In the meantime I found out that there is a button called 'Import Regions from Nodes' in the Advanced Options of Import Mesh. By using this the whole mesh including the 2D-regions are available in CFX5(.5).
Bernd
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 09:54
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
[Commercial meshers] Problem importing mesh in openfoam from fluent alessandr0 OpenFOAM Meshing & Mesh Conversion 3 September 4, 2008 14:41
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
problem related to mesh naveen CFX 3 March 25, 2006 09:47
