Home > Forums > CFX
Fortran installing(Urgent!)
Old   May 22, 2003, 21:03
Default Fortran installing(Urgent!)
Miko
Hi All,
I need use subroutine, and I think I must install Fortran in my computer(My OS is Windows and my CFX version is 5.5). Now my questions are: 1.what kind of Fortran I should install;2.where should I install, that is, what is the installing path? 3. is anything else I should pay attention to?
Old   May 24, 2003, 07:41
Default Re: Fortran installing(Urgent!)
zahid
Hi Miko CFX requires Digital Visual Fortran 6 for subtroutines. You can install it on any path. When you want to link a user subroutine you will have to follow following procedure: 1. Open DOS command window 2. Change the directory to Bin directory of Digital Visual Fortran. 3. write dfvars on DOS prompt. dfvars is a batch file. By executing it proper environmetal variables will be set. Now use are ready to use user subroutines. Hope it will help you. If you still have problems then contact me on e-mail.
Old   May 24, 2003, 09:26
Robin
Well, it is possible, but Zahid's suggestion will give you better results.
Robin
Old   May 25, 2003, 21:15
Miko
Thank you! after I installed Digital Visual Fortran6.5, also called Compaq Visual Fortran6.5 I think, everything includeing environmental variables was set automatically. So when I type "cfx5mkext my_subroutine_name.f" in the Command Line, it worked successfully and created two files ended with .DLL and .O in the subfolder "winnt" in the working directory. So I'm wondering if it means that now I can write my subroutine.
Thread Tools
Trackbacks are On
Fortran Compiler-CFX12.1 Araz CFX 12 November 2, 2014 13:46
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 22:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 20:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 09:34
