June 9, 2003, 08:51 |
Restart - Initial Values File
Hallo, i have a problem. I have a moving grid, so as I finish the first run I would like to start the second step (which is a *.def file) starting from the initial values file ( 001.res) . Obviously the mesh is different....but if I try CFX use the same initial mesh.....that it isn't right; so how I have to proceed??
please help me!! |
June 9, 2003, 12:12 |
Re: Restart - Initial Values File
Stex,
Selecting an initial values file will result in the solver using the mesh and results from this file with the physics of the specified .def file. What you probably want is to interpolate the previous solution onto the new mesh. To do this, simply use the interpolate function from the Solver Manager. Robin |
June 10, 2003, 04:56 |
If you're working with batch files it is useful to use the interpolator from the command line:
cfx5interp -def newmesh.def oldmesh.res Regards, cfd guy |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Problems with simulating TurbFOAM | barath.ezhilan | OpenFOAM | 13 | July 16, 2009 05:55 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
