USRBCS
Old   June 10, 2003, 13:03
Default USRBCS
shalaby Hemdan
I have measurments data at duct inlet and I want to apply this as a boundary conditions. I have the file. How can I read open and read this file in USRBCS to read velocity. In the file, I have U, V, and W.
Best regards
Shalaby
Old   June 10, 2003, 15:22
Default Re: USRBCS
Jan Rusås
Can't you specify the exact path in the open statement?
Old   June 11, 2003, 01:34
Default Re: USRBCS
Alex
Hi Shalaby!
Are you working with CFX 4 or -5?
Alexandra
Old   June 11, 2003, 01:43
Default Re: USRBCS
Alex
Hi!
These are the commands I used in an user routine in CFX 4 to read data from a file. Hpore this helps.
Alexandra
call FILCON('USRCVG','../datei.txt','OPEN','FORMATTED'
+ ,'OLD',idjjjj,iLREC,IOST,IERR)
if( IERR .eq. 0 ) then
write(*,*)'Error!'
endif
read(idjjjj,180) SCAL(inode,1,iscJx)
+ ,SCAL(inode,1,iscJy)
+ ,SCAL(inode,1,iscJz)
+ ,SCAL(inode,1,iscJg)
+ ,SCAL(inode,1,iscjh)
call FILCON('USRCVG','../datei.txt','CLOSE','FORMATTED',
+ 'OLD',idjjjj,iLREC,IOST,IERR)
180 FORMAT(5E16.6)
Old   June 11, 2003, 03:02
Default Re: USRBCS
shalaby Hemdan
hi Jan Rusås
The following what I have changed in USRBCS. In USER AREA 3 and USER AREA 5.
C+++++++++++++++++ USER AREA 3 +++++++++++++++++++++++++++++++++++++++++ C---- AREA FOR USERS TO DIMENSION THEIR ARRAYS
DIMENSION UVEL(40,80)
C C---- AREA FOR USERS TO DEFINE DATA STATEMENTS
OPEN(10,FILE='inlet_3.dat')
DO 1 J=1, 80
DO 1 I=1, 40
READ(10,*) UVEL(I,J) 1 CONTINUE
CLOSE (10) C C+++++++++++++++++ END OF USER AREA 3 ++++++++++++++++++++++++++++++++++ C C---TO SET THE U V W VELOCITY AT THE INLET C----INTEROGATE GETVAR FOR VARIABLES NUMBER
CALL GETVAR('USRBCS','U ',IU)
C SET IPHS = 1 FOR SINGLE PHASE FLOW
IPHS = 1 C USE IPREC TO FIND ADDRESSES
CALL IPREC('INLET','PATCH','CENTRES',IPT,ILEN,JLEN,KLEN ,
+ CWORK,IWORK)
C LOOP OVER PATCH
DO 103 K = 1, KLEN
DO 102 J = 1, JLEN
DO 101 I = 1, ILEN C USE STATMENT FUNCTION IP TO GET ADDRESSES C INODE = IP(I,J,K) C SET VARBCS
VARBCS(IU,IPHS,INODE) =UVEL(I,J) 101 CONTINUE 102 CONTINUE 103 CONTINUE C+++++++++++++++++ END OF USER AREA 5
Shalaby
Old   June 11, 2003, 05:42
Default Re: USRBCS
shalaby Hemdan
hi Alexandra
I am using CFX4.4. I think that is what you vare worked with. I want to know where can I write this command. If this in USRBCS in which user file.
Shalaby
Old   June 11, 2003, 06:44
Default Re: USRBCS
Jan Rusås
You do not specify the path for the file, which means that CFX will look for the file in maybe a temp dir or in the dir where put the calculations. I do not know if there is a smart option in CFX4 to open a file in the same directory as from where the calculations are started. But if you specify the correct path in you open statement it will find the file.
Old   June 11, 2003, 08:54
Default Re: USRBCS
Alex
You can write it in USRBCS in user area 5. Your input file must be in your working directory.
Alexandra
Old   July 16, 2003, 21:05
Default Re: USRBCS
jeff
Shalaby,
CFX-4 automatically copies all the files it "thinks" it needs for the run to a temporary directory just below your working directory (something like .CFX_temp) while the problem is running. Unfortunately it does NOT know to copy your data file, therefore it is ALWAYS one level up from the runtime temp directory. You should open data files then with the string "../data.dat" to indicate one level up.
Secondly, check the manual under USER FORTRAN for all the units used by CFX. I think opening unit 10 is risky as most of the first dozen units are used by various physical models and diagnotics output. I typically use a unit above 50 to be safe.
Also, unless you know that you will always be using a single block (2D test cases), use IPALL instead of IPREC. If your patch covers more than one block face, IPREC will only get one of the block faces. IPALL will get them all. You'll have to do some X,Y,Z matching to interpolate the data onto the patch, but it's safer.
Jeff
USRBCS in CFX 5 (actually, 5.7.1) ATS CFX 2 August 24, 2005 12:30
USRBCS RK CFX 2 February 23, 2005 04:10
Define scalar wall boundary by USRBCS? windhair CFX 2 November 26, 2003 08:00
usrbcs for inlet boundary Jesper Laursen CFX 2 May 31, 2002 16:34
USRBCS flag Alex CFX 0 February 12, 2002 10:41
