June 10, 2003, 22:04 |
Adaptive meshing in CFX-5.5
Hi all I have used adaptive meshing facility of CFX-5.5 for different problems. I think it does not produce satisfactory results. It is not so smart. Sometimes it refines the grid at places where it is not required. Has any body had good experiences in using adaptive meshing. If yes then please give me guidelines to obtain good results. Thanks
June 11, 2003, 18:37 |
Re: Adaptive meshing in CFX-5.5
Hi Zahid,
To get adaptive meshing to do good things you have to set a number of parameters correctly. The most important is use the correct variables to refine with. If your model has been refining where it is not required it sounds like you have selected the wrong variable. Choose one which _only_ varies in the region of interest. Also refining on variable*edge length can reduce over-refinement. It's worth a try too. Glenn |
CFX meshing | moon1234 | CFX | 0 | January 24, 2010 09:38 |
Which trailing edge is correct for meshing of aerofoils for CFX | LSC | CFX | 0 | May 10, 2009 12:45 |
CFX Meshing Error! | C Mc Guinness | Main CFD Forum | 0 | April 3, 2005 13:20 |
Geometry and meshing with CFX | Bob Crad | CFX | 3 | January 7, 2004 12:56 |
cfx, meshing + examples | mark | Main CFD Forum | 1 | December 21, 2000 23:10 |
