fail to install CFX5.6
Old   June 12, 2003, 17:59
Default fail to install CFX5.6
HANNAH LIANG
Hi, everyone,
I try to install CFX5.6 in my machine in which the window NT 4.0 pack 6 is used. There is no any problem in the process of installation. After that, I can use the CFX-Build, and solver looks good. But when I start the CFX-pre or CFX-Post, the same warning message comes out: CFX-Pre or CFX-Post exits with return code 2. Who knows what this mean? What happen in the installation? because of the software or hardware? Please give me some idea!
Thanks a lot.
Hannah
Old   June 12, 2003, 20:43
Default Re: fail to install CFX5.6
James
Hannah,
We installed on NT and have had no problems. It's most likely a problem with your system.
---James
Old   June 12, 2003, 21:18
Miko
Hi HANNAH LIANG! Is your computer connected to networks?
Old   June 13, 2003, 08:50
HANNAH LIANG
Hi, thank James and Miko. Yes, my machine is always on the line. The CFX5.5.1 works very well. The CFX-Build and solver are OK.
Hannah
Old   June 18, 2003, 08:13
Default Hardware Graphics problem
David M
There have been a number of cases like this, where CFX-Pre or CFX-Post fail to start, and they all seem to be related to a hardware graphics problem on Windows.
The workaround is to reduce the hardware acceleration on your machine. Go to the 'Control Panel / Display / Settings/ Advanced / Troubleshoot' section. Reduce the hardware acceleration by moving the slider to the left (try half way).
This should fix the problem.
Good Luck!
install openfoam in fedora Ahmed Khattab OpenFOAM Installation 32 September 23, 2011 11:11
unable to install openfoam 1.7 using apt-get maazhmd OpenFOAM Installation 7 July 24, 2011 11:18
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
How to Install OpenFOAM on 64 Ubuntu 9.04 hansel OpenFOAM Installation 62 March 19, 2010 14:43
the solvers of CFX4.4 and CFX5.6 Forrest CFX 2 September 5, 2003 04:34
