modifying a result file
Old   June 23, 2003, 13:36
Default modifying a result file
Bony Quach
I would like to modify a .res file made with CFX5. I already know it is possible to modify the "definition" part by using the -cfx5cmds- batch command, and to export almost the whole data with the cfxExport routines in C. But I still have problems using the cfxImport routines made for importing a mesh to a file. Are there batch commands, or routines to modify the mesh and Boundary conditions on a .def or .res file?? Moreover, are there other batch commands than playing a session file in cfx-build??
thanks, Bony Quach
Old   June 23, 2003, 13:42
Default Re: modifying a result file
Robin
Bony,
Physics definition is no longer done in Build. You can run CFX-Pre in batch (including Perl Power Syntax as with Post).
Robin
wmake compiling new solver mksca OpenFOAM Programming & Development 14 June 22, 2018 06:29
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 11:47
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 04:26
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
