INSUFFICIENT MEMORY ALLOCATED
Old   June 19, 2003, 14:27
Default INSUFFICIENT MEMORY ALLOCATED
xfshi
| *** INSUFFICIENT MEMORY ALLOCATED *** |
| Action required : Increase the real stack memory size. |
| If the situation persists please contact the CFX Customer Helpline |
| giving the following details:- |
| Requested space: 56603 words |
| Current allocated space: 18037086 words |
| Current used space: 17870629 words |
| Current free space: 166457 words |
| Number of free areas: 13 |
Fatal error generated in gParFlgRow
Message :- FULL : Failed to make a data area for ParFlgRow
gParFlgRow called by :- ASS_MASS_CS
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Stopped in routine gParFlgRow |
An error has occurred in cfx5solve:
The CFX-5 solver exited with return code 1. No results file has been
created.
End of solution stage.
Warning!
Old   June 19, 2003, 18:54
Default Re: INSUFFICIENT MEMORY ALLOCATED
Hi xfshi,
The memory estimate made by CFX at the start of the run was wrong and it has run out of memory. Next time you run the simulation, turn on advanced options, go to the solver tab, and put 1.2x in the "Memory allocation factor" box. This allocates an extra 20% memory space and should stop the problem. You may need to adjust the factor to suit your requirements. This is discussed in the documentation under memory management.
You should also report the problem to your CFX support person as it is possibly a bug in CFX, as the original error is caused by an incorrect memory estimate by the code.
*** INSUFFICIENT MEMORY ALLOCATED *** ?????? Pedro lima CFX 5 September 26, 2007 08:28
INSUFFICIENT MEMORY ALLOCATED Virag Mishra CFX 2 May 14, 2007 10:02
Insufficient Memory Allocated-error Juan Catelén CFX 2 April 4, 2007 03:57
INSUFFICIENT MEMORY ALLOCATED Error for FSI Cuong CFX 2 November 6, 2006 19:48
INSUFFICIENT MEMORY ALLOCATED Jan CFX 2 July 16, 2003 00:55
