June 23, 2003, 14:36 |
modifying a result file
I would like to modify a .res file made with CFX5. I already know it is possible to modify the "definition" part by using the -cfx5cmds- batch command, and to export almost the whole data with the cfxExport routines in C. But I still have problems using the cfxImport routines made for importing a mesh to a file. Are there batch commands, or routines to modify the mesh and Boundary conditions on a .def or .res file?? Moreover, are there other batch commands than playing a session file in cfx-build?? thanks, Bony Quach |
June 23, 2003, 14:42 |
Re: modifying a result file
Bony,
Physics definition is no longer done in Build. You can run CFX-Pre in batch (including Perl Power Syntax as with Post). Robin |
Display Modes | |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 07:29 |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 21:02 |
OpenFOAM Install Script | ljsh | OpenFOAM Installation | 82 | October 12, 2009 12:47 |
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 | BlGene | OpenFOAM Meshing & Mesh Conversion | 10 | August 6, 2009 05:26 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
