-   CFX (
-   -   no-slip wall boundary condition (
Atit Koonsrisuk June 22, 2003 06:04
I specified no-slip Wall boundary condition as one of the boundary conditions for my simulation. After solving, I export the velocity value along the line from wall to the free stream. I found that the velocity at the wall is not zero. In my case, it is 0.0321 m/s. Why isn't it zero? I think this might be the value at the center of the mesh next to the wall. Then how can CFX know, when it compute, that actually the velocity is zero at the wall? Thank you.
Marco Melo August 11, 2003 22:57
Re: no-slip wall boundary condition
When you are in post and you want to see velocity ther's 2 options Hybrid and Conservative (I think those are the names), you can choose these 2 options by toggle on one of them. In Hybrid you should see that the velocity is zero. I hope this will help you.
Stephen Waite July 9, 2014 17:24
Hello, I'm having the same problem, I set a constant temperature at a no-slip wall, however when I view the temperature and velocity in CFD-post at the wall they are not the values I specified.
I can see that the "conservative" boundary data tab is selected however I'm unable to change to hybrid because the boundary data tab is shadded (i.e. you can't select it). How can I change to hybrid?
evcelica July 10, 2014 17:10
You can only display hybrid values of pre-defined variables in CFD-POST, not used defined variables.
Like if you made a variable Mytemp = Temperature, there wouldn't be hybrid values for Mytemp, even though there are for Temperature.
Other than that, I don't know why else it wouldn't work?
