Interpolation res-->def
Hi, I have to do some restarts of changed meshes, but if I interpolate the result files ("cfx5interp -def newmesh.def oldmesh.res") and then start the *.def file with the *.res file as "Initial values file" it doesn't works infact the new solution use the old mesh. Please help me!!!
bye Stex |
Re: Interpolation res-->def
If you use the interpolation you don't need to specify an initial guess.
Example: cfx5interp -def newmesh.def -res oldmesh.res The next step is to run with the new mesh: cfx5solve -def newmesh.def Note that the newmesh.def will get a higher size. Regards, cfd guy |
thank you cfd guy. I'll try
