-   -   transient diffusion convection (http://www.cfd-online.com/Forums/cfx/19725-transient-diffusion-convection.html)
Volker Göke June 26, 2003 09:34
Hi CFX 5.6 world! I've modelled the following problem successfully for the stationary case but have no idea how to work in some transient modifications:
Object: Rectangular Parallelepiped (20* 20* 50 mm(height)) with a capillary tube (right-angled to one side wall) some millimeters above the bottom.
Fluid domain - so far only one,
Fluid model : variable mole fraction, isotherm
2 Inlets (Bottom, Top) 1 Outlet (Capillary tube)
The composition at the two inlets differs (otherwise no diffusion due to concentration gradient - okay?!)
Result:A relative sharp z-gradient on the level of the capillary tube. Also transport occurs in x and y direction.
Now the real problem: The bottom inlet isn't usefull anymore. But I would like to start the simulation with an initial concentration distribution (only depending on the z-coordinate). A step function (any height from the bottom th the top should be possible) would be enough for the first guess. How can I implement this? - even sleeping on the manual wasn't successful!
Thanks for all helpful hints!
Volker
Phil June 26, 2003 16:20
Re: transient diffusion convection
Step functions are easy with CEL. The bump tutorial has an example of using a step function to initialize variables (in that case, it is used to initialize volume fraction for a free surface calculation).
