Drag and Lift Calculations
Old   June 26, 2003, 09:48
Default Drag and Lift Calculations
Sam
Hi everybody, how can i calculate the drag and lift on a submerged body using CFX5.5. Hoping for an early response. Thanks in advance.
Old   June 26, 2003, 18:47
Default Re: Drag and Lift Calculations
Hi Sam,
At the end of the output file is a summary of normal and viscous forces on the surfaces. You can get drag and lift from that.
Glenn
Old   June 27, 2003, 06:37
Bob
Sam, to simplify your problem you could group your surfaces into a single wall boundary condition, so getting the forces for the complete body.
Old   June 30, 2003, 10:20
Louwrens
Of course, gotta enable "output equation flows", which will do the calculation of the pressure integrals, otherwise Post can't determine the forces
Old   June 30, 2003, 15:29
Robin
Actually, in version 5.6 Post can estimate the flows/forces etc. if the expert parameter is not set.
Robin
Lift and Drag ??? Yogibear STAR-CCM+ 5 November 2, 2023 17:14
How does FLUENT calculate lift and drag? xTamx420 FLUENT 0 May 30, 2011 13:35
Lift and Drag Monitor Point Values Converging to Zero Josh CFX 24 May 9, 2011 10:38
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 27, 2007 23:38
Drag and Lift Daniel Fisher Phoenics 2 April 8, 2005 03:51
