compressible two phase flow in CFX4.4
following is error message and my command file.
CFX-4 | Solver | forrtl: error (73): floating divide by zero CFX-4 | Solver | Image PC Routine Line Source CFX-4 | Solver | psolvempiNT.exe 004BED98 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0044CC18 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0041DEE6 Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 004186AC Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0040B73B Unknown Unknown Unknown CFX-4 | Solver | psolvempiNT.exe 0040541C Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | Unknown 02290190 Unknown Unknown Unknown CFX-4 | Solver | runsolve4: Job completed CFX-4 | Solver | Output file : /tmp/m07.fo CFX-4 | Solver | CFX-4 | Solver | Finished. >>CFX4 :>OPTIONS TURBULENT FLOW TWO DIMENSIONS HEAT TRANSFER COMPRESSIBLE FLOW LAMINAR FLOW TRANSIENT FLOW NUMBER OF PHASES 2 :>MODEL TOPOLOGY :>CREATE BLOCK BLOCK NAME 'BLOCK-NUMBER-1' BLOCK DIMENSIONS 40 20 :>CREATE PATCH PATCH NAME 'INLET' BLOCK NAME 'BLOCK-NUMBER-1' PATCH TYPE 'INLET' PATCH LOCATION 29 31 20 20 1 1 HIGH J :>CREATE PATCH PATCH NAME 'PRESS' BLOCK NAME 'BLOCK-NUMBER-1' PATCH TYPE 'PRESSURE BOUNDARY' PATCH LOCATION 9 11 1 1 1 1 LOW J :>MODEL DATA :>TITLE PROBLEM TITLE 'test' :>AMBIENT VARIABLES TEMPERATURE 2.9100E+02 :>PHYSICAL PROPERTIES >>COMPRESSIBILITY PARAMETERS PHASE NAME 'PHASE2' INCOMPRESSIBLE >>COMPRESSIBILITY PARAMETERS PHASE NAME 'PHASE1' WEAKLY COMPRESSIBLE UNIVERSAL GAS CONSTANT 8.3140E+03 FLUID MOLECULAR WEIGHT 2.8950E+01 REFERENCE PRESSURE 1.0130E+05 >>FLUID PARAMETERS PHASE NAME 'PHASE2' VISCOSITY 1.0000E-05 DENSITY 38.0 >>STANDARD FLUID PHASE NAME 'PHASE1' FLUID 'AIR' STANDARD FLUID REFERENCE TEMPERATURE 2.9100E+02 >>HEAT TRANSFER PARAMETERS PHASE NAME 'PHASE2' THERMAL CONDUCTIVITY 2.3400E-04 FLUID SPECIFIC HEAT 1* 0.000000E+00 ENTHALPY REFERENCE TEMPERATURE 2.8800E+02 >>MULTIPHASE PARAMETERS >>PHASE DESCRIPTION PHASE NAME 'PHASE1' GAS CONTINUOUS MINIMUM VOLUME FRACTION 1.0000E-05 MODIFY EMPTY CELL VELOCITY 0.0000E+00 >>PHASE DESCRIPTION PHASE NAME 'PHASE2' SOLID DISPERSE MEAN DIAMETER 1.0000E-03 MINIMUM VOLUME FRACTION 1.0000E-05 SOLID PRESSURE RESTITUTION COEFFICIENT 6.0000E-01 COMPACTION VOLUME FRACTION 6.4000E-01 MODIFY EMPTY CELL VELOCITY 0.0000E+00 >>MULTIPHASE MODELS >>MOMENTUM INTER PHASE TRANSFER SINCE >>INTER PHASE TRANSFER MODELS >>MOMENTUM FIRST PHASE NAME 'PHASE1' SECOND PHASE NAME 'PHASE2' >>PARTICLE DRAG MODEL FLOW REGIME 'ERGUN' >>TRANSIENT PARAMETERS >>FIXED TIME STEPPING TIME STEPS 100* 1.000000E-03 INITIAL TIME 0.0000E+00 :>SOLVER DATA :>PROGRAM CONTROL MAXIMUM NUMBER OF ITERATIONS 10 MASS SOURCE TOLERANCE 1.0000E-06 :>CREATE GRID :>SIMPLE GRID BLOCK NAME 'BLOCK-NUMBER-1' DX 40* 3.000000E-03 DY 20* 3.000000E-03 DZ 3.000000E-03 X START 0.0000E+00 Y START 0.0000E+00 Z START 0.0000E+00 :>MODEL BOUNDARY CONDITIONS :>INLET BOUNDARIES PHASE NAME 'PHASE1' PATCH NAME 'INLET' NORMAL VELOCITY 3.0000E+00 VOLUME FRACTION 9.0000E-01 TEMPERATURE 2.9300E+02 :>INLET BOUNDARIES PHASE NAME 'PHASE2' PATCH NAME 'INLET' NORMAL VELOCITY 2.0000E+00 VOLUME FRACTION 1.0000E-01 TEMPERATURE 2.9300E+02 :>PRESSURE BOUNDARIES PHASE NAME 'PHASE2' PATCH NAME 'PRESS' PRESSURE 0.0000E+00 VOLUME FRACTION 0.0000E+00 :>PRESSURE BOUNDARIES PHASE NAME 'PHASE1' PATCH NAME 'PRESS' PRESSURE 0.0000E+00 VOLUME FRACTION 1.0000E+00 :>STOP |
