sliding grids
Old   July 1, 2003, 04:25
Default sliding grids
Giuseppe
I have a problem when I try to use sliding grids; by the way, the simulation of the centrifugal pump produce high residual mass. this cause the end of the simulation.
have you an idea ?
Thank you very much!
Giuseppe
Old   July 2, 2003, 10:28
Default Re: sliding grids
Nyatoto
It is difficult to understand your problem at this stage. Would you be more generous with your information. When does this occur, immediately or...?
What are your: -speed -mesh -time step -underelaxation factors -descritization schemes (spatio-, temporal-) etc..??
regards Nyatoto
Old   July 3, 2003, 03:57
Giuseppe
Hi, Nyatoto
The simulation diverge immedyately, after 7-8 iterations.
I have 1400 rpm , my model of rotor has structured mesh with 4 elemet for each arc with an angle of ten degrees.
the fluid was water
I used :
>>FIXED TIME STEPPING
TIME STEPS #NSTEP * #DT
with
#CALC
PI=3.1415926;
DEG=PI/180.0;
#ENDCALC /* ... ASTEP IS GRID MOVEMENT ANGLE PER TIME STEP ... */
#CALC
NSTEP = 144;
MAXIT = 50;
CRIT = 1000;
ASTEP = 2.5*DEG;
#ENDCALC /* ... WORKING VALUES ... */
#CALC
RPM = 100;
OMEGA = RPM*2.0*PI/60.0;
REVOLT = 2.0*PI/OMEGA;
DT = REVOLT*ASTEP/(360.0*DEG);
#ENDCALC
i used default under relaxation factors and the options:
THREE DIMENSIONS
BODY FITTED GRID
UNMATCHED GRIDS
CARTESIAN COORDINATES
TURBULENT FLOW
ISOTHERMAL FLOW
INCOMPRESSIBLE FLOW
TRANSIENT FLOW
TRANSIENT GRID
furthermore i have:
>>FALSE TIMESTEPS
U VELOCITY 0.8
V VELOCITY 0.8
W VELOCITY 0.8
:>REDUCTION FACTORS
K 0.55
EPSILON 0.55
:>DEFERRED CORRECTION
K START 0
K END #MAXIT
EPSILON START 0
EPSILON END #MAXIT
I ran two simulations with the following boudaries conditions:
1) inlet + outlet
with inlet velocity of 3,5 m/s
2) simulation all circuit
No inlet No outlet
I hope for some help
Thanks in advance! Giuseppe
Old   July 3, 2003, 08:28
Nyatoto
Hi Giuseppe,
Is your RPM 1400 or 100? Please check your FC file. Let me first assume that everything is right with your geo file (BC, grid,etc).
Your false time steps appear to be too high, it is generally a good practise to start with low false time steps (if you need them). In your case I would like to know what your under relaxation factors are! These too can initially be set very low, sometimes the default ones may be too high, expecially if your flow is highly turbulent. I assume you are using k-e model, which will INITIALY give you huge errors if you have a flow with high swirl (I suspect your model has this) and the solver ambitiously tries to get fast solution with high under relaxation factors.
Another thing is the discretization schemes: You may start with, say upwind or Hybrid. For time scheme I prefer fully implicit.
I suggest you try under relaxation factors in the range of u,v,w=0.1-0.3 or lower, P can be as high as 0.5 or 0.7, k,e about 0.3-0.5. You can increase these later as you wish. similarlt try smaller times steps to begin with.
Lastly, select your out put monitor position wisely.
Hope this helps Nyatoto
Polyhedra and sliding mesh? rockewan FLUENT 5 December 1, 2018 19:07
A question about dynamic overset grids JXIA Main CFD Forum 4 January 10, 2008 03:50
helicopter simulation with sliding grids Mark Render Main CFD Forum 0 February 14, 2003 08:07
unmatched boundaries for sliding grids Markus CFX 1 August 16, 2001 19:06
Sliding box validation required Glenn Horrocks Main CFD Forum 1 March 1, 1999 07:00
