INSUFFICIENT MEMORY ALLOCATED
+--------------------------------------------------------------------+ | | | *** INSUFFICIENT MEMORY ALLOCATED *** | | | | Action required : Increase the real stack memory size. | | | | If the situation persists please contact the CFX Customer Helpline | | giving the following details:- | | | | Requested space: 864000 words | | | | Current allocated space: 11918009 words | | Current used space: 7199807 words | | Current free space: 4718202 words | | Number of free areas: 30 | | | +--------------------------------------------------------------------+
Details of error:- ---------------- Error detected by routine MAKDAT CDANAM = FLUXC CDTYPE = REAL ISIZE = 864000 CRESLT = FULL +--------------------------------------------------------------------+ | Writing crash recovery file | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | The CFX-5 solver exited with return code 1. No results file has | | been created. | +--------------------------------------------------------------------+ End of solution stage. +--------------------------------------------------------------------+ | Warning! | | | | The CFX-5 Solver has written a crash recovery file. This file has | | been saved as /SbS4_007.res.err and may be | | an aid to diagnosing the problem or restarting the run. More | | details should be available in the solver output section of the | | output file. | +--------------------------------------------------------------------+ +--------------------------------------------------------------------+ | The following user files have been saved in the directory | | /SbS4_007: | | | | mon | +--------------------------------------------------------------------+ This run of the CFX-5 Solver has finished. Can someone tell me how to correct this? thanks |
Re: INSUFFICIENT MEMORY ALLOCATED
check tha total no of nodes and allocate memory considering 30% more node
e.g say u have 100K nodes then in 'others' box in memory allocation, write following -nnode130k this should work for u J- |
Jan,
Click on the advanced options tickbox in the solver manager. Click on the "Solver" tab if you are doing a solver run, "Partitioner" tab if the partitioner is failing, and increase the amount of real stack space being alocated by a factor. Enter something like 1.2x in the "real" memory box to allocate 20% more. Neale |
