Home > Forums > CFX
Real Gas Properties
Old   July 15, 2003, 08:01
Default Real Gas Properties
mbga8ejf
Hi
Does anyone know how i select the refrigerant r134a as the working fluid?
also does anyone have RGP tables for other refrigerants?
Ed
Old   July 15, 2003, 09:23
Default Re: Real Gas Properties
Min
Please go to "Fluids Edite" creating new material.
Old   July 16, 2003, 01:00
Neale
Ed,
Open the materials selector. Hit the little "open folder" box on the right side. Load up the file "MATERIALS-redkw.ccl". r134a is one of the materials in that file.
Ask your support person if you need a pressure and temperature range for r134a that the RGP table does not cover.
Refrigerant RGP tables in CFX-5 are also available if you purchase a copy of REFPROP from NIST. If you do that then you can call your support rep and they will gladly supply you with whatever RGP table you need for any refrigerant in the REFPROP library.
You can also, if you like, generate your own RGP file if you decide on an equation of state, constituitive relationship and saturation curve data. The format of the file is documented in the Real Fluids section of the solver modelling documentation.
Neale
Thread Tools
Trackbacks are On
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 2 June 24, 2011 00:59
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
mass flow in is not equal to mass flow out saii CFX 2 September 18, 2009 08:07
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
