July 17, 2003, 14:27 |
rotating domain
If I set a domain to be a rotating domain, does the cutout solid in my domain will also rotate? Thanks, Jackie |
July 17, 2003, 19:27 |
Re: rotating domain
Depends on what you define on the walls of your cutout solid. You can put them in the rotating domain without further specifications. Them they will rotate. You can specify a counter rotating wall. Then, the net velocity will be zero.I think you can also put them in the stationary domain with the same result.
Pascale |
July 18, 2003, 03:06 |
Re: rotating domain
Thank a lot Pascale Fonteijn
Vertical Axis Wind Turbine Rotating Domain Problems | TWaung | CFX | 4 | May 1, 2012 03:14 |
transient simulation of a rotating rectangle | icesniffer | CFX | 1 | August 8, 2009 07:25 |
Difference b/t rotating wall and rotating domain? | Juno Kim | CFX | 2 | February 20, 2007 20:08 |
rotating domain in rotating domain, different axis | Robert Stringer | CFX | 3 | December 4, 2006 07:04 |
Size of rotating domain | Adam | CFX | 4 | November 28, 2006 10:28 |
