Home > Forums > CFX
"substituting" grids in 5.6
Old   August 16, 2003, 11:11
Default "substituting" grids in 5.6
Louwrens
Can I substitute one grid with another in Pre (same geometry and physics) without having to define the whole problem all over again? I've read that if you create a new GTM file in Build the additions made in a previous session of Pre is overwritten... or don't I understand it correctly? Surely having the pre-processing separate from the grid-generation should allow for substituting grids?
L
Old   August 17, 2003, 18:37
Default Re: "substituting" grids in 5.6
Hi Louwrens,
I found the best way of doing this is to start a new simulation, import your new grid, then import the CCL from the original problem. Of course, you need to have the original CCL file, this can be easily created with cfx5cmds (see the documentation if you don't know what this means).
Your simulation will be ready to go straight to the def file if it has the same domain and boundary condition names, otherwise a small amount of finishing up will be required.
Regards, Glenn
Old   August 18, 2003, 02:24
Louwrens
Thanx Glenn
Checked it out quickly, it's exactly what I'm looking for.
Cheers
L
Old   August 18, 2003, 04:40
Michael Bo
You don't have to use cfx5cmds. Just import the CCL-file from either a .def or a .res file. (Choose from drop doen list). The CCL will be extracted from that. - Michael Bo
Old   August 25, 2003, 17:09
Robin
Better still, save the FLOW>FLOW and required LIBRARY sections of your CCL directly from PRE. You can then use this as a template. When you start a new problem, choose the Model Library option and browse to select the ccl you saved. If you have a mesh with all the same names, the boundary conditions will be applied automatically.
Regards, Robin
Thread Tools
Trackbacks are On
OpenFOAM - structured or unstructured Grids ? thomasduerr OpenFOAM Meshing & Mesh Conversion 18 October 10, 2014 06:31
A question about dynamic overset grids JXIA Main CFD Forum 4 January 10, 2008 04:50
Reloading grids in Pre Pascale Fonteijn CFX 1 July 7, 2003 13:33
UDF Face Fluxes & Partitioned Grids Greg Perkins FLUENT 0 April 6, 2001 01:50
Can I define grids motion as a time functions Darcy CFX 4 March 29, 2001 21:14
