August 19, 2003, 10:17 |
Heat Transfer Coef
Hi
Can anyone help with the unit of the heat transfer coefficient in CFX POST ? Currently it is defined as [Kg s^-3 k^-1], But i would like to convert it to [W m^-2 K^-1]. Thanks in advance Regards jens |
August 19, 2003, 10:58 |
Re: Heat Transfer Coef
Dear Jens,
[W]=[N m s^-1]=[kg m^2 s^-3] So [W m^-2 K^-1] equals [Kg s^-3 K^-1]. Regards, Jaap |
August 20, 2003, 04:27 |
Yeah, it's 6 or half dozen. It's up to you to choose.
<big> <big> <big> ;-) </big> </big> </big> |
August 25, 2003, 16:56 |
Hi Jens,
You can modify the display of specific quantities from the Edit menu in Post. In your case the numeric value will be the same, but you can have Post display the units you prefer. Regards, Robin |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
WALL HEAT TRANSFER COEF...AGAIN | Carl | CFX | 2 | July 8, 2005 01:35 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
