September 4, 2003, 11:24 |
Bingham model in CFX5
Hi everyone,
I found it is hard to realize Bingham model in CFX5 because I can not input shear stress directly, although shear strain can be input into a Fortran subroutine with ease. Any suggestion is appreciated. Ding |
September 4, 2003, 18:37 |
Re: Bingham model in CFX5
Actually I can realize it using Fortran subroutine. But the problem occurs when I try to run CFX-Solver 5.6. Then I follow the procedures in Tutorial 9 -- Flow through a Butterfly Valve, then I got the similar error message:
+--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Unable to load symbol inlet_velocity from D:\JW\Simulation\CFX56\tutorials\3\winnt\PipeValve _inlet.dll: The specified procedure could not be found. | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | USER ROUTINE: Wprof could not be loaded. Please check the Library Path, Library Name and Calling Name. For FORTRAN user routines, the Calling Name should be in lower case. | | Writing crash recovery file | +--------------------------------------------------------------------+ ---------------------------------- Error in subroutine GET_SPECVAR : A recursion problem was encountered when evaluating the expression for "VEL-1_FL1" at the following location: "PipeValve". Please carefully check that the result of your expression does not depend on itself. GETVAR originally called by subroutine Write_mfloip +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | The CFX-5 solver exited with return code 1. No results file has been created. End of solution stage. Anybody can tell me the reasons and what should I do to modify the settings? Ding |
Display Modes | |
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 15:25 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
