September 9, 2003, 14:42 |
CFX build 5.6
Hello All Experts
I seem to have a problem trying to use the mouse functions such as zoom, translate, drag etc, when using CFX build on the LINUX O/S. I have looked through the manual and can't find any help regarding configuration in cfxbuild 5.6. Does anyone out there know what I need to do to get all the mouse features to work as normal. Everything works fine when I use CFX_post??? Can anyone help me....??? Cheers |
September 9, 2003, 16:17 |
Re: CFX build 5.6
Richard,
I have the same problem. I don't think rotate is supported in Build for LINUX. To translate or zoom, use the middle mouse button with the Shift or Ctrl key respectively. Does that help? Not having the rotate feature is somewhat inconvienient, but can be over come with a bit of persistance. Jonathan |
September 9, 2003, 16:21 |
Re: CFX build 5.6
Hello Johnathan
Thanks for getting back to me so quickly! I will try your suggestion. Thanks Richard |
September 9, 2003, 18:52 |
Re: CFX build 5.6
This does work with Linux. Make sure your middle mouse button function is not being overridden by your window manager.
Robin |
September 10, 2003, 01:54 |
Re: CFX build 5.6
Everythink works fine under Linux. Make sure, your NumLock key is off!!! ps:it does not work for me under Windows (2000). Also the rendering of the black screen is not working properly. Is there any interaction with the Xserver? Has anyone any idea where could be the problem? matej |
September 10, 2003, 03:32 |
Re: CFX build 5.6
Hi Matej
I have it set up on windows 2000 and everything works fine. I have managed to get it working on Linux also (mandrake 9.0) and all appears to be ok now. What version of X are you using on Linux, I am not sure if this makes a difference but I am using version 4.x.x,? |
September 10, 2003, 04:24 |
Re: CFX build 5.6
I have mandrake 9.1 and its default X version: 4.3 patch level 5mdk to be precise. I guess, while it is XFree86 4.x.x.. the 'x's do not matter that much. I'm giving up on Windows. matej |
September 10, 2003, 10:23 |
Re: CFX build 5.6
Turning Num Lock off solved my problems. Thanks. That had been bugging me for a long time.
Jonathan |
September 10, 2003, 12:20 |
Re: CFX build 5.6
#9 |
Search for the file /etc/X11/XF86Config
Make a copy first! Then search for Section "InputDevice" Identifier "Mouse0" Make the section look like below: Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "IMPS/2" Option "Device" "/dev/psaux" Option "ZAxisMapping" "4 5" Option "Emulate3Buttons" "no" EndSection Especially the "IMPS/2" did the trick for me. If it does not help, you can set the last option to "yes" which will emulate the middle mouse button by pressing the left and right button. This is espcially convenient if you do not have a middle mouse button at all. Astrid |
Can CFX 5.6 model combustion of a sprayed liquid? | Doug | CFX | 0 | July 3, 2004 03:46 |
Porous Media in CFX 5.6 | Cui | CFX | 0 | June 30, 2004 15:18 |
CFX 5.6: Dispersion Coefficient/ Concentration | shir | CFX | 0 | November 26, 2003 09:02 |
have CFX 5.6 came into market or not?? | prasanth | CFX | 4 | May 21, 2003 21:45 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
