WATER CLOSET DRAINAGE
HI HAS CFX AN ABILITY TO SIMULATE THE WATER MOVEMENTS INSIDE THE WATER CLOSET TO TEST ITS FUNCTIONALITY ??(DRAINAGE OR WATER CONSUMPTION)
Re: WATER CLOSET DRAINAGE
Yes,
the flow in a sanitary system is an open channel flow and requires the resolution of the interface between the water and the air. This is often called free-surface flow. Further, in such equipment one may be interested in the movement of another phase which can be modeled as either an Eulerian fluid or as a Lagrangin particle in CFX-5.6 Regards, BAK_FLOW |
Hello dear
I just saw your problem and learned that you got its solution. I have just started my MS and am working in the same field. It would be very nice of you if you could please help me. Feel free to contact me on mechovator@yahoo.com With best regards Mechovator |
Have a look here:
Decreasing Water Consumption in Toilets. Optimization of a sanitary discharge valve using ANSYS CFX: http://www.ansys.com/industries/cons...oiletvalve.htm Optimization of a sanitary discharge valve using a numerical approach: http://www.wseas.us/e-library/confer...rs/498-704.pdf Numerical and experimental optimisation of a gravity driven free-surface flow: http://www2.dem.uc.pt/antonio.gameir...SEAS_paper.pdf |
