[Sponsors] | |||||
I want to define a internal boundary in a block, where a constant value is fixed on this surface, is it possible in CFX 4.4 using user subroutine? Which type of patch should I define there?
Thanks |
I copy the follow from the cfx document in page3-570. I hope it is helpful. Btw: Are you using the same ID in aoxue Forum ?
It is sometimes the case that you wish to prescribe the velocity at some internal point of the flow domain rather than giving a source of momentum. In this situation there are two ways of proceeding. First, it is possible to use an internal inlet and outlet, but they must be situated on a solid region. The second method, which should only be used with great care, uses source terms in the momentum equations by setting: SP = -c SU = c*value AM = 0 for all six facial components |
Thanks, that is me.
![]() Thanks for you information, but what I want to define there is not velocity. In short, it is a additional user scalar, and I need to set a boundary condition for such scalar inside the flow domain, and sovle a Poisson equation for such it, and this will have no direct influence to other variables. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| inlet velocity boundary condition | murali | CFX | 5 | August 3, 2012 08:56 |
| How to define the velocity_inlet boundary condition with existed data for a face? | Byron | FLUENT | 4 | September 4, 2010 03:47 |
| setting boundary conditions on internal edges | Renate Stump | FLUENT | 4 | November 7, 2008 10:55 |
| boundary conditions for internal faces | Tom Pendrey | FLUENT | 1 | March 5, 2007 18:25 |
| Internal boundary condition | Fred | CFX | 0 | December 28, 2004 13:57 |
