Home > Forums > CFX
Conduction-only run possible?
Old   October 17, 2003, 09:07
Default Conduction-only run possible?
Martin
Has anyone tried to do only heat conduction (thermal equation only) solution for a solid in CFX5.6? I know it is possible in Fluent, but now I use CFX and I would really appreciate this possibility.
When exporting def file from CFXPre, it complains about no fluid domain being set up.
Thanks for your ideas.
Martin.
Old   October 17, 2003, 09:38
Default Re: Conduction-only run possible?
Robin
Hi Martin,
CFX-5 requires that you have at least one fluid domain. If you only want to solve heat conduction, do the following:
1. Define your fluid properties to match your solid properties, 2. Set up your fluid Domain as you normally would, but set the turbulence model to laminar, 3. Set your velocity initial guess to zero, 4. Set your advection scheme to upwind to avoid vertex gradient calculations, 5. Set the expert parameter "solve fluids = f" to turn of the hydro equations.
If you have additional solids, you can define them as CHT solids.
Regards, Robin
Thread Tools
Trackbacks are On
SnappyHexMesh OF-1.6-ext crashes on a parallel run norman1981 OpenFOAM Bugs 5 December 7, 2011 13:48
Help-Edit Run in Progress BalanceChen CFX 0 March 30, 2011 09:23
How to run and save tranisent case on Cray XD1 Leon FLUENT 0 October 3, 2006 21:59
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 16:36
Restatring run Tim CFX 2 March 3, 2006 12:54
