October 28, 2003, 11:14 |
"Frozen" velocity field. Robin?
Hi!
Can someone tell me what happens in the solver when the expert parameter "solve fluids" is set to f? The hydrodynamic equations are not solved, I know that much. I also understand that this means that only the velocity field is frozen, the temperatures in the fluid are still changing. But how does CFX calculate viscosity in the fluid? Using Sutherland's formula? And density, does that change? Would be grateful for answers... /Märta-Karin |
October 28, 2003, 13:38 |
Re: "Frozen" velocity field. Robin?
Hi Märta-Karin,
If solve fluids is to f, the solve is not solving for a new mass and momentum field. This has nothing to do with the viscosity calculation. Density may still vary with temperature, depending on you fluid, but it will no longer be consistant with the solution. Viscosity is specified in the material properties as a value or expression. Regards, Robin |
Display Modes | |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Reconstruction of velocity and pressure field | Jianglan | Main CFD Forum | 0 | October 6, 2008 01:04 |
fixed velocity field | Glen | CFX | 3 | August 28, 2006 13:17 |
velocity field | Faiz Ahmed | Main CFD Forum | 0 | March 5, 2006 11:11 |
transient temperature field with constant velocity | Törnquist | CFX | 0 | September 16, 2003 05:22 |
