CFX4 Build
Can somebody in this forum give me a hand/help on how to generate structured grid in CFX4 Build for a circular pipe?
Re: CFX4 Build
You need to create a H block, meaning that you have a central square that is connected to the outer (4) circle of the pipe. It is well described in the manual.
Ups -did not see your post further down
Re: CFX4 Build
Hmm, not sure what is going on - better take a nap
Re: CFX4 Build
Just before Jan takes a nap, remember that (say) if y becomes your radial direction in the solver, it should not be less than zero.
Eldoret |
Re: CFX4 Build
For a 3D carthesian calculation why should it be a problem with y less that zero. (Still ZZZZZZZZ) Jan
Re: CFX4 Build
It only matters in a 2D axisymmetric grid (Y's should all be positive). In a 3D grid it matters not.
There's a standard example in the docs. Jeff |
