molar mass
Hi, All
In tutorial 13 of CFX 5.6, the molar mass of acid(H2SO4) is set to be 19.52 kg/kmol. How to get this value? Can anyone help to list the details of deriving Molar mass from molecular weight? Thanks! |
Re: molar mass
Aslo: How can I get the kinematic diffusity of a chemical? From literature? or by experiment?
Re: molar mass
This looks like an average molar mass of a aqueous solution of H2SO4. Pure H2SO4 = 2*1+1*32+4*16 ~98 kg/kmol.
Pascale |
Re: molar mass
Yes, from literature, Perry or something. However if conditions are turbulent, then fill in 1e-10 or so.
Pascale |
Re: molar mass
Hi,Pascale,
Thanks for your reply. As you said, if conditions are turbulent, then fill in 1e-10 or so---Does this mean the kinematic diffusity will be material independent for turbulent flow? Are you sure of this? By the way, could you please list some literatures about kinematic diffusity? Thanks a lot! |
Re: molar mass
Yes, I am sure.
'Properties of gases and liquids' from Reid is a good start. Pascale |
Re: molar mass
Thanks a lot for your information!
Best regards! |
Re: molar mass
Hi, Pascale,
As you said, the kinematic diffusity will be material independent for turbulent flow. Could you please provide the literature sources for such a conclusion? I am trying to use this conclusion in my thesis work, but I do need to put a reference for that. Thanks again! Jim |
Re: molar mass
pfffff..
Try the cfx-manual as a start. And further... Bird, Stewart and Lightfoot? Pascale |
Re: molar mass
Thnaks!
