molar mass
Old   November 28, 2003, 12:38
Default molar mass
jim
Hi, All
In tutorial 13 of CFX 5.6, the molar mass of acid(H2SO4) is set to be 19.52 kg/kmol. How to get this value? Can anyone help to list the details of deriving Molar mass from molecular weight?
Thanks!
Old   November 28, 2003, 12:49
Default Re: molar mass
jim
Aslo: How can I get the kinematic diffusity of a chemical? From literature? or by experiment?
Old   December 1, 2003, 09:03
Pascale Fonteijn
This looks like an average molar mass of a aqueous solution of H2SO4. Pure H2SO4 = 2*1+1*32+4*16 ~98 kg/kmol.
Pascale
Old   December 1, 2003, 09:04
Pascale Fonteijn
Yes, from literature, Perry or something. However if conditions are turbulent, then fill in 1e-10 or so.
Pascale
Old   December 1, 2003, 11:55
jim
Hi,Pascale,
Thanks for your reply. As you said, if conditions are turbulent, then fill in 1e-10 or so---Does this mean the kinematic diffusity will be material independent for turbulent flow? Are you sure of this?
By the way, could you please list some literatures about kinematic diffusity?
Thanks a lot!
Old   December 2, 2003, 04:14
Pascale Fonteijn
Yes, I am sure.
'Properties of gases and liquids' from Reid is a good start.
Pascale
Old   December 2, 2003, 10:55
jim
Thanks a lot for your information!
Best regards!
Old   December 3, 2003, 10:31
jim
Hi, Pascale,
As you said, the kinematic diffusity will be material independent for turbulent flow. Could you please provide the literature sources for such a conclusion? I am trying to use this conclusion in my thesis work, but I do need to put a reference for that.
Thanks again!
Jim
Old   December 4, 2003, 08:34
Pascale
pfffff..
Try the cfx-manual as a start. And further... Bird, Stewart and Lightfoot?
Pascale
Old   December 4, 2003, 11:40
jim
Thnaks!
Running dieselFoam error adorean OpenFOAM Running, Solving & CFD 119 February 1, 2016 14:41
Problem setting with chtmultiregionFoam Antonin OpenFOAM 10 April 24, 2012 09:50
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
