Temperature at Opening
Old   December 18, 2003, 10:45
Default Temperature at Opening
cui
Hi, Friends:
I am running a simulation where I need to impose a constant temperature at the outlet. In the middle of the domain, there is a heat source and the incoming flow is at 298K. If I use Outlet for the outlet boundary, it does not allow me to specify temperature. Therefore, I go with Opening for the outlet and specify 298K at the outlet. The problem is CFX always ignors the specified temperature, instead, it treats it like an insulation (zero temperature gradient). Could anyone tell me how to enforce a constant temperature at an outlet or opening? Your help is greatly appreciated
Old   December 18, 2003, 11:52
Default Re: Temperature at Opening
Jonathan
Cui,
How can you define a constant temperature at the outlet if heat is being convected downstream?
The only time the temperature set at the outlet would be used is if there was inflow as well as outflow - the inflow would enter at the specified temperature.
Jon.
Problem with zeroGradient wall BC for temperature - Total temperature loss cboss OpenFOAM 12 October 1, 2018 06:36
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
opening temperature for the opening BC sujay CFX 5 June 2, 2010 08:04
High temperature methane+air Peter FLUENT 5 January 26, 2009 18:04
temperature at opening BC Amit Katiyar CFX 1 November 2, 2003 21:58
