starting with dump file
Old   January 12, 2004, 09:35
Default starting with dump file
Dougal McQueen
I am having trouble strating a run from a dump file. I have the error:
:>MODEL BOUNDARY CONDITIONS ERROR OPENING RESTART FILE ON UNIT NUMBER 16 THE CFX-4 SOLVER HAS BEEN STOPPED BY SUBROUTINE OPENIO
Anyone got any hints? Also, how does the solver "look" for the correct dump file (does it need an appropriate name, and if not how are files prioritised)?
Lastly if I want to set initial variables and read in variables from the dump file, will these conflict?
Many thanks in advance
Dougal McQueen
Old   January 14, 2004, 06:42
Default Re: starting with dump file
Dougal McQueen
In case anyone else out there gets this error. It was caused by the solver not "finding" the dump file, no matter what I named it. You can point the solver to the dump file on the command line using -r e.g. runsolve4 -c m01.f -f aaa.f bbb.f -r dump_file.dmp
Does anyone know where references to command line instruction can be found?
Thanks
Dougal
Old   January 14, 2004, 16:32
James Date
Hi
Been a while since is used CFX-4.4 but i think you need to make sure the .fc and .dmp restart files have the same number.
Another thing, whats the point restarting from a dump file and also specifing intial field variables? The restart data will just be over written! This is just like starting a fresh run.
Regard James
Old   January 15, 2004, 04:03
Dougal McQueen
I am using the dump file as the initial condition for most variables (u, tke, e etc..), but have scalars added in the second run.
Many thanks
Dougal
Old   January 16, 2004, 19:03
Jeff
For command line parameters use "runsolve4 -h".
You can also look in the top of your .fo file when running from the environment to see what command line command was used to create the run.
Your SET INITIAL GUESS values will overwrite anything that's read in from the dump file. Useful for re-initializing a scalar field but not the flow solution.
Jeff
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 17:33
gcc and executable file from Mac to Linux simone Marras Main CFD Forum 0 April 8, 2007 15:49
Results saving in CFD hawk Main CFD Forum 16 July 21, 2005 20:51
