User CEL or Junction Box routine?
Old   December 16, 2003, 08:25
Default User CEL or Junction Box routine?
Lexi
Hello!
I have tables with the pressure and temperature dependencies of my materials. Do I have to take user CEL or junction box routines to read the data?
Lexi
Old   December 17, 2003, 00:26
Default Re: User CEL or Junction Box routine?
Neale
User CEL functions should work fine to define the properties (density=f(T,p) and Cp=f(T,p)). You will probably still need a junction box routine in the "User Input" location to read your table data though.
Neale.
Old   December 17, 2003, 16:37
Hi Lexi and Neale,
You can import your CEL tables into CFX-Pre, or you can copy/paste them into the CEL text file and write them into the definition file with the cfx5cmds command. You won't need a junction box routine to read it in.
Glenn
Old   December 18, 2003, 00:15
Neale
Yes, but you must use the cloud of points interpolation for two-dimesional functions (eg: rho(T,p)).
This is somewhat awkward because the cloud of points method requires 3D input data, so you must put zero in for the third column, and the data is unstructured so you must copy the ordinate values a bunch of times that is really unecessary.
Normally the cloud of points is for clouds of x,y,z values, that's why it's a bit awkward to use it for T,p tables.
However, as you say, it can be done without a junction box.
Neale
Old   December 18, 2003, 06:17
Bart Prast
I wouldn't recommend cloud of points for material properties as it used to be very slow (CFX improved it but I do not know to what extend). Better to write your own interpolation routine (structured for rectangular P,T domain) as you can put in all the acceleration in there.
Old   December 18, 2003, 16:37
Hi Neale,
Good point - now I understand the issue.
Glenn
Old   January 22, 2004, 08:52
S. Balasubramanyam
Hi, I have a relationship between temperature and liquid fraction. The relationship varies for different ranges of temperature. During runtime I need to update the liquid fraction by taking temperature as input. Following the examples in the manual I have written a small fortran code and created a dll. But I am getting an error, which says that it is unable to load the symbol. Also it says that the specified procedure could not be found. I am not able to understand this. Can anyone help me? Thanks in advance.....balu.
Difference between Junction BOX routine & CEL expression in a 1 way FSI vmlxb6 CFX 1 March 1, 2011 08:50
user CEL or Junction Box? xck1986 CFX 6 May 30, 2010 08:24
junction box routine and CEL function bornspur CFX 2 February 3, 2009 02:24
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
