July 29, 2014, 08:54 |
Error when using Boussinesq Model
Julian
Rep Power: 11 |
Hello everybody,
I am simulating a simple pipe flow with a heated pin in it with forced and natural convection. When I run the Solver with the full buoyancy model (variable density) everything is fine. But when I try to use the boussinesq model (constant density, but a value for the thermal expansivity) i get this error: Error detected by routine PEEKR CDANAM = ../../HEATM/TFC/SIGMA/VALUE CRESLT = NONE Current Directory : /FLOW/PHYSICS/ZN1/FL1/TURBM/BUOYTURB +--------------------------------------------------------------------+ | ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine MEMERR | | | | | | | | | | | +--------------------------------------------------------------------+ I think maybe a value 'Sigma' is missing, but I dont know how I can fix it. Did anyone have a similar Problem or any idea how to fix it? Thank you, CFDJ |
July 29, 2014, 15:43 |
Rep Power: 32 |
If you are more specific on the details of the turbulence model, perhaps someone here can help you.
For example,
For example, the Buoyancy tutorial provided assumes laminar flow. You can change it to turbulence flow, and apply similar settings and see if it works for you. |
July 30, 2014, 02:47 |
Julian
Rep Power: 11 |
thank you for your reply. I thought maybe the error code whould be enough, but here are some further informations: -I'm using the SST Model, however I've already tried others - same error -I use Production and Dissipation option with a turbulente Schmidt Number of 0.9 and a Dissipation Coefficient of 1. I also tried to run the simulation with no buoyance sub model - still same error -I'm using CFX 15.0 thank you for your help CFDJ |
July 30, 2014, 06:08 |
Rep Power: 143 |
If you turn buoyancy off entirely (not just the buoyancy turbulence stuff) do you get the error?
July 30, 2014, 07:07 |
Julian
Rep Power: 11 |
when I choose the 'Non Buoyant' option, I don't get the error. My values, wenn I choose the 'Buoyant' option are: x = 0 m s^-2 y = 0 m s^-2 z = -9.81 m s^-2 Ref. Temp : 572.15K Ref. Location : Automatic |
July 30, 2014, 07:13 |
Rep Power: 143 |
In that case the error is most likely in the way you have set up your materials. What materials are you using?
July 30, 2014, 07:20 |
Julian
Rep Power: 11 |
Actually I want to work with a liquid metal. But if I run the simulation using the predefined 'Water' Material, I still get the error.
July 30, 2014, 07:43 |
Rep Power: 143 |
The error message is cryptic and I cannot be sure what it is getting at. But I suspect you are missing an essential material property associated with the Buoyancy turbulence model.
July 30, 2014, 07:56 |
#9 |
Julian
Rep Power: 11 |
You might be right, but it's confusing that it doesn't work, even if i choose the predefinded Materials like 'Water' or 'Air at 25 C', which also use the Boussinesq Model. I didn't change them. Is it possible that something written in these materials is wrong?
July 30, 2014, 08:00 |
#10 |
Julian
Rep Power: 11 |
Sometimes I get additionaly this Error in an extra Window:
No data source for Workspace, cannot monitor Solver data. |
July 30, 2014, 08:09 |
#11 |
Rep Power: 143 |
What do you mean "something written in these materials is wrong?". Something is wrong in your model, that is why you are getting the error. But I can assure you many people have done buoyancy simulations in CFX before (me, for instance) and it worked just fine for us.
I very rarely run CFX inside workbench. It just adds another layer of things to go wrong (as you just found out). So I run CFX in stand alone mode - except in the rare cases when you need workbench to drive parameters or do FSI or something like that. |
July 30, 2014, 08:25 |
#12 |
Julian
Rep Power: 11 |
I also use stand alone mode. The additional window is just an error-window.
And I know that my model is wrong, but if I use the Libary Material Water and there is still an Error, then the Error can't arise from the Material setup, or am I wrong? |
July 30, 2014, 18:34 |
#13 |
Rep Power: 143 |
Can you post your CCL?
July 31, 2014, 02:47 |
#14 |
Julian
Rep Power: 11 |
I think I have found the problem.
July 31, 2014, 02:58 |
#15 |
Julian
Rep Power: 11 |
I defined a function for the turbulent Prandtl Number, making it variable. This caused the error, when I tried to use the Boussinesq Model. Now that I know where the error comes from I can try to fix it. Thank you for your support!
February 3, 2021, 08:41 |
#16 |
thomas
Rep Power: 11 |
Hi @CFDJ, I am facing exactly the same problem (variable turbulent Prandtl number for a mixed convection case). I also noticed that the variable Prandtl number works fine for a non-buoyant case, but not when the buoyancy is activated. Did you manage to make a mixed convection case run, i.e., with buoyancy effects?
boussinesq, buoyancy |
difference between incompressible k-epsilon model and compressible k-epsilon model | yhy20081016 | OpenFOAM Running, Solving & CFD | 3 | January 19, 2016 07:49 |
Model assemble - meshing strategy | Aeronautics El. K. | Pointwise & Gridgen | 7 | August 8, 2015 03:30 |
K - epsilon VS SST turbulence model | Maicol | Main CFD Forum | 0 | November 30, 2012 16:25 |
LES and combustion model | Margherita Cadorin | CFX | 0 | October 29, 2008 05:24 |
Boussinesq model reference temperature? | David Agostinho | CFX | 2 | July 4, 2004 11:55 |
