Home > Forums > CFX
Restriction on filename?
Old   February 18, 2004, 03:59
Default Restriction on filename?
Atit Koonsrisuk
Is there any restriction on the filename and folder name defined in CFX? I have the file, named "10_10_0p2_1.def", in the folder, named "roof_height". I got the error message that I do not understand in Solver. Thank you very much.
Atit
Old   February 18, 2004, 04:16
Default Re: Restriction on filename?
Atit Koonsrisuk
I got the error message say something about filename checking in Build with the file named "roofExpand".
Old   February 18, 2004, 05:04
Pascale Fonteijn
I am aware of spaces. You cannot use these in directories and file names. Your file name looks correct to me.
Pascale
Old   February 18, 2004, 11:03
Johnson
It may be because your def file name begins with a number instead of a letter - I know there are restrictions in CCL on this.
Johnson
Old   February 26, 2004, 16:14
Martin Bowers
I think there are many, many, MANY cryptic restrictions on all sorts of text fields. I avoid using any special characters besides - (dash) and so far that seems to work.
I think there is / was a restriction on total absolute path length too.
Old   March 3, 2004, 02:39
Neale
The problem is with CFX-5 CEL expressions that can contain references to named locations (eg: boundaries subdomains etc.)
So, don't use a dash in any material, boundary, domain name etc... this wont work because it can get misinterpreted as a CEL expression.
Neale
Thread Tools
Trackbacks are On
Motorcycle CFD champion STAR-CCM+ 6 March 19, 2011 07:57
convert fileName to double braennstroem OpenFOAM Programming & Development 6 February 21, 2011 08:59
restriction and prolongation operators rookie Main CFD Forum 0 June 8, 2006 02:28
smoothing iterations before restriction CFD Student Main CFD Forum 1 May 20, 2006 00:06
Time Step Restriction Valdemir Main CFD Forum 2 May 6, 2003 04:55
