CCL
Old   March 2, 2004, 08:21
Default CCL
Ogbeni
I have 3 CCL's, one to monitor points,another for vorticity and lastly to invoke parallel run. How can I combine all of them ?
Old   March 2, 2004, 16:01
Default Re: CCL
Hi Ogbeni,
Use the "Import ccl" option in CFX-Pre, and use the append option.
Glenn
Old   March 2, 2004, 18:32
Default Re: CCL
Jeff
......or......
use the -ccl switch on the command line. This will let you add any number of ccl files to your main run. I use this all the time to add ccl in temporarily.
Jeff
Old   March 3, 2004, 01:46
Default Re: CCL
Neale
Yes you must use Jeff's suggestion in this case.
Glenn's suggestion will blow away your vorticity CCL. CFX-Pre does not nicely handle library variables yet.
Neale
how to start using CCL Norberto Marcelo Nigro CFX 9 August 11, 2019 07:04
CCL Timestep Lists max3.2 CFX 4 June 29, 2011 10:13
Ansys cfx ccl help achauhan Main CFD Forum 0 December 30, 2010 20:38
Getting Inlet Velocity Values through CCL or User Shraman CFX 3 May 1, 2007 14:58
How to write CCL 2 computers Kemi CFX 1 May 3, 2004 18:09
