-   -   Inlet and outlet flow rate (http://www.cfd-online.com/Forums/cfx/20209-inlet-outlet-flow-rate.html)
Neser March 2, 2004 08:23
My model is to spray water through a nozzle to be in direct contact with a hot air. The calculater of CFX post gave me the following results:
Inlet water mass flow rate is 1.76242 kg/s Inlet air mass flow rate is 0.4454 kg/s
however, Outlet water mass flow rate is -29.808 kg/s outlet air mass flow rate is nearly zero
can you help me about this. Is this result have a meaing (outlet mass flow rate is greater than the inlet). Is there any wrong I did
regards
Glenn Horrocks March 2, 2004 17:02
Re: Inlet and outlet flow rate
Hi Neser,
Are you sure the simulation has converged properly? It doesn't sound like it.
Glenn
