Particle simulation in CFX 5.6
Hi
I have a problem with the particle simulation in CFX 5.6. I inject particle in 5 different mass range into a pipe system. But after 1/4 of the pipe lenght the particle track stops. Why is this happing ? Any hints. Regards Jens |
Re: Particle simulation in CFX 5.6
Jens, could be the simultion time of the particls has run out ? There is a time limit in the setup and if the particls are still in the domain when this time limit runs out then they just stop. Check through the GUI's and on particle setup and you will find this, just make it larger and it should solve your problem Bob
