Tide angle problem when meshing
Old   March 21, 2004, 11:39
Default Tide angle problem when meshing
Tudor Miron
Hi, I'm having a problem creating a surface mesh for a car body. It is tide angles that cause the problem. How ever it's impossible to avoid it in CAD model if I want it to represent real car closely. For example when modelling rear underbody diffuser - it starts at shallow angle from flat bottom. So there's a tide (2.8deg) internal angle at start of diffuser side wall. It HAS to be there - what to do??? I was making a relatively fine mesh with MC on car body with 20mm lengh scale. Trying to put a Point MC at that tide angle with lengh scale 0f 0.1mm didn't help.... Please HELP!!! Thank you Ted
Old   March 21, 2004, 16:27
Default Re: Tide angle problem when meshing
Hi Ted,
Are you using CFX-Build or ICEM CFD 4.CFX?
Glenn
Old   March 22, 2004, 09:51
Tudor Miron
Hi Glenn, I'm using CFX Build. I'd like to add to my question. I can still make a mesh when after warning message. Question is how bad it is for mesh quality and ultimately how does it effect results accuracy?
Thank you Ted
Old   March 22, 2004, 16:43
Hi Ted,
I've moved onto ICEM CFD 4.CFX now and am trying to purge CFX-Build from my mind. This means I can't help you with the meshing problem unfortunately. As for the warning message, the proof is in the pudding - have a look at the final mesh with CFX-Post and decided yourself whether the mesh is acceptable. It has a number of tools for analysing mesh quality.
Glenn
Old   March 22, 2004, 17:24
Tudor Miron
Thanks any way
Ted
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
[GAMBIT] fac meshing problem, not skewness bugra ANSYS Meshing & Geometry 0 September 3, 2010 07:40
problem meshing with low y+ cesco FLUENT 8 February 23, 2009 05:12
Problem meshing with Gambit Adrian FLUENT 8 October 7, 2008 08:39
problem meshing in GAMBIT khairul hadi Main CFD Forum 1 August 20, 2008 17:13
