March 21, 2004, 11:39 |
Tide angle problem when meshing
Hi, I'm having a problem creating a surface mesh for a car body. It is tide angles that cause the problem. How ever it's impossible to avoid it in CAD model if I want it to represent real car closely. For example when modelling rear underbody diffuser - it starts at shallow angle from flat bottom. So there's a tide (2.8deg) internal angle at start of diffuser side wall. It HAS to be there - what to do??? I was making a relatively fine mesh with MC on car body with 20mm lengh scale. Trying to put a Point MC at that tide angle with lengh scale 0f 0.1mm didn't help.... Please HELP!!! Thank you Ted
March 21, 2004, 16:27 |
Re: Tide angle problem when meshing
Hi Ted,
Are you using CFX-Build or ICEM CFD 4.CFX? Glenn |
March 22, 2004, 09:51 |
Hi Glenn, I'm using CFX Build. I'd like to add to my question. I can still make a mesh when after warning message. Question is how bad it is for mesh quality and ultimately how does it effect results accuracy?
Thank you Ted |
March 22, 2004, 16:43 |
Hi Ted,
I've moved onto ICEM CFD 4.CFX now and am trying to purge CFX-Build from my mind. This means I can't help you with the meshing problem unfortunately. As for the warning message, the proof is in the pudding - have a look at the final mesh with CFX-Post and decided yourself whether the mesh is acceptable. It has a number of tools for analysing mesh quality. Glenn |
March 22, 2004, 17:24 |
Thanks any way
Ted |
[ICEM] ICEM meshing problem | xyq102296 | ANSYS Meshing & Geometry | 6 | October 28, 2010 10:09 |
[GAMBIT] fac meshing problem, not skewness | bugra | ANSYS Meshing & Geometry | 0 | September 3, 2010 07:40 |
problem meshing with low y+ | cesco | FLUENT | 8 | February 23, 2009 05:12 |
Problem meshing with Gambit | Adrian | FLUENT | 8 | October 7, 2008 08:39 |
problem meshing in GAMBIT | khairul hadi | Main CFD Forum | 1 | August 20, 2008 17:13 |
