April 23, 2004, 08:38 |
mesh nodes amount??
who can tell me how much the Max mesh nodes amount can be solved by CFX5? Thanks!
April 26, 2004, 18:12 |
Re: mesh nodes amount??
If you run a large parallel job it can be huge - hundreds of millions to billions.... But pre- and post-processing might be a bit of a challenge. In my experience, on a Intel windows machine you can run a simple compressible or incompressible simulation (that is no extra variables, phases or chemistry) with 1 million nodes in 2GB ram with two processors. If you have only one processor the biggest job you will be able to run on a windows machine will be about 1.5GB. Regards, Glenn |
April 27, 2004, 00:17 |
I think for large parallel job bottle neck is partitioner requirements. On windows machine with 1GB imposible (in my case) to partition mesh with aproximate amount of nodes of 3 millions. But on this machine under linux it is possible.
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 05:25 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
