visualize the initial and/or boundary conditions |
April 28, 2004, 10:10 |
Dear all, IŽd useful any trick to visualize in post the initial conditions or the BC. In complex geometries it is easy to make mistakes or do not set the right (physically right)ones in corners, for example. How do you do it(if you do)?
thanks pi |
April 28, 2004, 12:15 |
Re: visualize the initial and/or boundary conditio
Try to set the following expert parameters:
solve fluids = f solve tke eps = f This will turn off the equation solver (assuming you're using k-epsilon model). Run for 1 iteration only and you'll be able to see your initial conditions. Take a look at the CFX-5/etc/5.6/RULES file and you'll find the suitable expert parameters to turn off the equations for your specific case. Good luck, G. G. |
April 28, 2004, 18:26 |
There are other ways of doing it which do not require you to do a dummy simulation. For steady state runs you can, just after starting a run press "Backup Run"; or in CFX-Pre you can set it up to output the initial conditions with output control/backup results and set the iteration list to 0. For transient runs, in CFX-Pre use Output Control/Transient Results, and set the time list to zero. Regards, Glenn |
April 29, 2004, 00:03 |
To visualize the initial condition for a steady state run use the following expert parameter:
backup file at zero =t This will create a backup file at 0th iteration! ie before the start of the solution so that you can view the initial guess. IN cfx-5.7 you can visualize the boundary conditions in Pre itself.. I have not tested out the same for initial conditions! |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
MRFSimpleFOAM goes divergenced! | renyun0511 | OpenFOAM Running, Solving & CFD | 0 | November 19, 2009 02:11 |
Computational time | sunnysun | OpenFOAM Running, Solving & CFD | 5 | March 16, 2009 03:32 |
MRFSimpleFoam amp cyclic patches | david | OpenFOAM Running, Solving & CFD | 36 | October 21, 2008 21:55 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 12:53 |
