Home > Forums > CFX
creating an expression
Old   April 28, 2004, 05:10
Default creating an expression
ioana
Hello everybody!
I have to model the absorption coefficient of the air and gas mixture and this is:
a = 0.01 if T< 323 K
a=0.01 +(3/49/377)(T/-323) if 323<=T<700 K
a=3.5 +(3.5/700)(T-700) if T>700
How can I set this? I tried to set it the in the expression editor but I don't know how to set the "if" argument...
Can you give me a suggestion?
Ioana
Old   April 28, 2004, 08:25
Default Re: creating an expression
pi
Hi Ioana, the only way using CEL that comes into mind is using nested step functions. If your picewise function a is a=a1 for T<T1 a=a2 for T between T1 and T2 a=a3 for T>T2, then try:
f1=step(T-T1) f2=step(T-T2) A(T)=a1+(a2-a1)*f1
so then your desired function is a(T)=A+(a3-A)f2
regards pi
Old   April 29, 2004, 11:06
ioana
Hi Pi!
There is no other way to do it? I don't know CEL and unfortunately I do not understand of word of your explanation. I saw that the help doesn't provide more suggestions in this direction, so I guess I have to look for another way. ioana
Old   April 29, 2004, 11:35
pi
Hi Ioana, the typing in my message yesterday was not very clear. sorry. Type the right units for the absortion coef where is indicated below and load it into pre as a CCL:
LIBRARY:LIBRARY CEL:CEL
EXPRESSIONS:EXPRESSIONS
T1=323 [K]
T2=700[K]
f1=step((T-T1)/1 [K])
f2=step((T-T2)/1 [K])
a1 = 0.01 [units?]
a2=0.01 +(3/49/377)(T-323[K]) [units?]
a3=3.5 +(3.5/700)(T-700[K]) [units?]
A=a1+(a2-a1)*f1
a=A+(a3-A)*f2
END
END
END
hope it is more clear. regards
Old   April 30, 2004, 04:10
ioana
Dear Pi,
Thank you very much for your help. I will load the file in pre.
Have a nice day,
Ioana
Thread Tools
Trackbacks are On
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
Lift, Drag Vs time chart,calculations Jamesd69climber CFX 8 February 17, 2005 18:23
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
