How to write CCL 2 computers
Old   May 1, 2004, 14:39
Default How to write CCL 2 computers
Kemi
Hello I wish to write a ccl to proportion memory b/w 2 computers for CFX5.6, 1 Computer has 2Gb and another has 750Mb, I need a ccl to ratio the memory. I need help urgently since I can not do any simulations, I keep getting error message not enough memeory. Thanks
Old   May 3, 2004, 19:09
Default Re: How to write CCL 2 computers
Hi Kemi,
It is not normal to change the partition weightings by using ccl. Most people do it either using the Solver Manager or the command line (when starting the solver from batch mode).
But if you really want to set the partition weights in the ccl file then start a run from the solver manager with different partition weights and have a look at the ccl in the output file it produces. That will show you the format of how to set it up.
Glenn
mesh file for flow over a circular cylinder Ardalan Main CFD Forum 7 December 15, 2020 14:06
CCL Timestep Lists max3.2 CFX 4 June 29, 2011 11:13
Ansys cfx ccl help achauhan Main CFD Forum 0 December 30, 2010 21:38
Phase locked average in run time panara OpenFOAM 2 February 20, 2008 15:37
UDF to write interp files Karl FLUENT 6 February 7, 2002 13:10
