Home > Forums > CFX
CFX-VNC: UNSOLVED
Old   May 6, 2004, 00:46
Default CFX-VNC: UNSOLVED
KKA
Test, I tried what you said but it didn't work. I will be much appreciated if you can view my reply to my previous message. On the other hand new ideas from other members are welcome.
This is the problem: I used VNC to access my UNIX machine. But I anytime I want to run CFXpre or CFXpost, it freezes and displaying error message of :"Xlib extension GLIX is missing and will display my remote access UNIX macine, say," kka.cfx-vncunsolved.help". But just CFX5 command works though. Is only the GUI with more graphics that has problem. My local machine is PC-Windows based.
Thanks alot in advance.
Old   May 6, 2004, 02:09
Default Re: CFX-VNC: UNSOLVED
matej
what the test is suggesting is what is in the manual and applies only to X clients like Exceed. Since you're using VNC, you don't need this.
But the error message says, that you are missing some OpenGL compatability on the windows side. It means that the CFX is sending to VNC client on your win computer some instructions it does not know, how to handle. So installing Xserver on windows (Exceed in case of CFX) seems to be the option. It may be on the CFX install disks, ( I don't know, I'm not using windows at all). There used to be a variable-when set on SGI, no OpenGL instructions were used, but I don't think it would work in your case.
Running VNC server on linux is not safe, anyway. I did not help much, though
good luck.
matej
Old   May 6, 2004, 03:06
test
It seems you donot have Exceed... You will have to load the same.. It is a hird party software and doenot come with the standard installation of windows.
Old   May 6, 2004, 08:50
deLuther
Don`t forget about Exceed3D, without it Pre and Post will not work on your local machine.
Old   May 7, 2004, 17:45
Juan Carlos
It seems your desktop/pseudo X server does not support OpenGL.
Have you tried using mesa instead of OpenGL?
cfx5pre -graphics mesa
or
cfx5post -graphics mesa
Hope it helps
Juan Carlos
Thread Tools
Trackbacks are On
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 02:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
