Home > Forums > CFX
Old   May 7, 2004, 12:19
Default CFX-VNC:exportDISPLAY
Hi test
I log on to telnet. But it didn't work. this is what I did:
:log on:myUSEERID
wd: I entered
output %(machinename):exportDISPLAY=ISP:0.0 the error message:Command not found
Please lemmie if I did the right thing. Regards
Old   May 10, 2004, 03:38
Default Re: CFX-VNC:exportDISPLAY
you are typing the command wrong..
it is export (space) Display=
Where the IP address is that of your windows machine. If you dodnot know the IP address of windows machine, go to command prompt and type "ipconfig"
Hey this will only work if u have exceed installed on ur windows machine, else u will get the same error
Old   May 17, 2004, 09:11
hey test thanks alot. But unfortunately I don't 've exceed installed on my windows PC. I try if I can get one. Thanks alot.
Thread Tools
Trackbacks are On
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 03:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
CFX pressure in Simulations problem nasdak CFX 1 April 14, 2010 13:22
PhD using CFX Rui CFX 9 May 28, 2007 05:59
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
