Surface 3 is not an exterior face of a 3-D Region.
Old   May 9, 2004, 22:28
Default Surface 3 is not an exterior face of a 3-D Region.
tuki72
Could you advice me how to create an internal wall to use for cfx5.6?? Internal wall will be used to transfer heat only.
AR
Old   May 10, 2004, 01:17
Default Surface is closed and also contains singularity
tuki72
There is an error I find in BUILD (cfx 5.6)
"Surface is closed and also contains singularity"
Any idea why I get this?
Old   May 11, 2004, 08:41
Default Re: Surface is closed and also contains singularit
Helper
You have created a cone-like surface in your geometry. You need to split the cone into two surfaces from the point to the base in order to mesh it.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[Gmsh] gmsh and boundary layers kanuk OpenFOAM Meshing & Mesh Conversion 11 August 14, 2015 12:35
[ICEM] How to generate sunstructured "all-tri patch-dependant" surface mesh in ICEM? jash ANSYS Meshing & Geometry 19 July 23, 2013 18:48
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
